User interface suggestion : color lines and curves for gradients
Observations
  • The Color line / Curve setting is located in the Settings menu, easy to miss
  • Switching between Color line and Curve does not preserve the gradient mapping, when it would be possible to do so
  • The control line setting "by luminance" is not obvious
Suggestions:
  • Move the Color line / Curve setting as a dialog box control
  • When switching between Color line and Curve, preserve the gradient mapping, if it is possible to do so
  • The control line setting "by luminance" is not obvious, relabel as "Sort by luminance"
