question : Soft Light
Often I use Soft light to increase brightness of an image. For example by applying a gradient.
Soft Light works very well ; however, sometimes 100% white does not increase the brightness enough.
I can add the same transformation over to achieve results as desired.
Question
Is this the right way to proceed ?
Is there a way to boost the effect of soft light ?
Possible new feature
Could there be a new feature whereby the effect of a transformation is boosted beyond 100 % ?
Re: question : Soft Light
Almost anything you can do with Soft Light you can also do with a brightness curve which is what I would use instead as it is much more powerful and lets you use the histogram as a guide.
Thank you
