Update Available - Version 8.0.465
An update is available to Version 8.0.465 (11-Nov-2024)
Fixed problems with keyboard accelerators not working in batch mode.
Continued reworking how batch processing works. Removed single step mode and added a new Process or Skip transformation you can add to provide the functionality of single step mode. Added a new Edit command to disable/enable breakpoints. Modified the Copy transformation to let you quickly switch among up to four inputs. This can also be used within a batch process to provide additional manual control of the processing workflow. See the updated help file and Batch Processing.pdf for details.
Hovering the cursor over an Image Select control thumbnail now displays the name of the associated image, if any.
Re: Update Available - Version 8.0.465
Thank you. Eager to try !
