Level transformation resetting in batch
Is there a way to pause a batch at the Level transformation, but make it reset to doing nothing for each new image in the batch? There is a switch like this in Crop options.
Re: Level transformation resetting in batch
Levels and Color already has several settings regarding how to handle new images. For example Dynamic Range can be Reset, Custom or Auto which will do nothing, to the same thing to each image, or expand the range of each image. Similarly Color Balance and be Auto or Custom. To avoid changing the current and any future images in a Batch, just reset everything and click OK.
OK, that makes more sense. Added for next release.
In a similar spirit, could Rotate-Mirror be equipped with a similar batch reset option?
Yes there is a setting in Level, I just added it a few days ago.
Yes, but is it possible to reset Rotate-Mirror in batch? If I rotate an image by 90 deg, for instance, I would like the next image in the batch not to remember that.
