Flood-Fill Mask Changes Upon Re-entering (or refreshing) Transformation
jfoster
Post by jfoster »
Flood-Fill Mask changes when Mask Transformation is Re-Entered
NOTE: In reading the Help, it seems that I am probably missing something here, however IMO the mask that exists upon exiting the mask transformation should not change upon re-entering it. I guess what I’m not clear on is how to set multiple individual seed points versus how to set beginning and ending line points.
Anyway, the following steps create a mask, and that mask changes when the Mask Transformation is re-entered (or refreshed in the case where a transformation is added before the Mask Transformation – even if the added Transformation makes no change to the image).
To reproduce:
1. Start PWP 8.0.454
2. Add the Color Wheel test pattern
3. Add the Mask Transformation.
4. Select New Mask
5. Select the Flood-Fill tool
6. Select 1 Flood-Fill spot with a click on the image near the red vertex
7. Select another individual Flood-Fill spot with a Shift-Click near the yellow vertex
8. Prepare to create a Flood-Fill region by Shift-Clicking near the magenta vertex
9. Complete the Flood-Fill region (began in Step 8) by Clicking near the center
10. Note the three individual mask areas created
11. Exit the Mask Transformation and re-enter it.
12. Select Re-open Mask Dialog Box
13. Note now that the three individual mask areas are all joined
Re: Flood-Fill Mask Changes Upon Re-entering (or refreshing) Transformation
I made the following change in 454:
Shift-Click sets to end of the seed line without starting a new flood fill. (Used to start a new flood fill)
Ctrl-Shift-Click applies the current flood fill and starts a new one. (Used to be Shift-Click)
Sorry for the confusion, but this seemed like the most logical way to add the seed line feature.
See the help file for more details.
jfoster
Post by jfoster »
Did you consider implementing the additional Flood-Fill feature in a backward compatible fashion?
Click and Shift-Click would perform as before, but Control-Shift-Click becomes the end point of seed-line running back to the previous Click or Shift-Click point. There is additional logic needed to define the state-diagram status at the end of the Control-Shift-Click. But again it could be backward compatible - another Click would remove the previous mask region (that was formed by the line instead of the point), and another Shift-Click would simply add another seed point.
A way to conceptualize this backward-compatible approach would be to view the original implementation as using zero-length lines for each seed point and the new feature merely adds the ability to stretch out the seed points into non-zero length lines (with Control-Shift-Click).
In any case, the steps in the above post do produce a serious bug in the current release. I came across this in a production edit where I inserted a Clone-Tool prior to the Mask Transformation. A little research showed that the bug happened even when a Clone-Tool made no changes to the image (or the Mask Transformation was re-opened).
These steps do not create 3 individual masks, since 7,8,9 simply define/re-define the seed line endpoint
There is only one region and its shape is based on the seed line defined by 6 and 9, so I think this is working correctly (or at least according to the current interface).
To quote the updated help file:
Click -- sets the seed point.
Shift-Click -- sets the seed line endpoint.
Ctrl-Click -- resets the seed line endpoint.
Ctrl-Shift-Click -- applies the current flood fill and starts a new one
If I was starting from scratch, this is probably the way I would have set it up and I think it is the cleanest implementation. I admit the first few times I used I a did a Shift-Click when I should have done a Ctrl-Shift-Click, but thereafter it became easier.
jfoster
Post by jfoster »
My bad. I botched steps 7,8, and 9. Here are the corrected steps:
7. Select another individual Flood-Fill spot with a Ctrl-Shift-Click near the yellow vertex
8. Prepare to create a Flood-Fill region by Ctrl-Shift-Clicking near the magenta vertex
9. Complete the Flood-Fill region (began in Step 8) by Shift-Clicking near the center
Attached is a screen-shot video illustrating the problem.
FloodFillBug.zip
(566.87 KiB) Downloaded 150 times
OK, I got it now. Fixed for next release.
