Update Available - Version 8.0.440
An update is available to Version 8.0.440 (17-Jul-2024)
Curve Control: Fixed tool tip for Y coordinate probe.
Fixed problem in File Open causing crash when doing Batch operations is there are no files to execute. Tool bar buttons for batch operations are now grayed out if there are less than 2 files in the list.
Added warning when starting a batch operation if none of the transformations downstream from the File Open is an Export, Print or Slide Show.
