Update Available - Version 8.0.434
An update is available to Version 8.0.434 (8-Jun-2024)
Help About box: added information on Memory Load. If this number gets near 100% you are running out of physical memory.
Palette Tool: added a checkbox to let you display a copy of the palette color patches in the lower right corner of the main image area. For many transformations and controls, you can click or shift-click on one of these color patches and the effect will be the same as if you clicked or shift-clicked on that color in the image. You can use this feature, for example, to create new control points on curves or to set control points for selective color correction.
