Update Available - Version 8.0.430
PAn update is available to Version 8.0.430 (14-May-2024)
Added an experimental group of three transformations under the Transformation/Split command from the main menu. For details, see the new document Split Processing.pdf which can be downloaded from the web site. These transformations may not work perfectly or may change significantly in the future or disappear, so please don’t use them for production work on your images.
Scratch Removal Tool: fixed problems with simultaneously dragging and rotating the mouse wheel. Rotating the mouse wheel is now ignored while dragging a control point.
Fixed problem with reading GPS latitude from JPEG files due to bug in Windows JPEG reader.
