Update Available - Version 8.0.428
An update is available to Version 8.0.428 (28-Apr-2024)
Mask Dialog Box: fixed problem of some controls not being hidden when doing a Reset from the Mask Settings Menu. Fixed problems with Mask Separate Tool, especially for black and white images. Fixed problems with referencing bypassed masks (e.g. a transformation refers to a blurred version of a mask image generated by the Masks transformation and then the blur transformation is bypassed.)
When offering to replace a missing file when opening a script, if you select the Edit Pathname option, you can now enclose the pathname in quotes which will then be removed and ignored. A new option to specify a replacement folder has also been added.
File Open: fixed some problems with double clicking on a File Open that had no files selected. Renamed File Open Multiple to File Open List.
Fixed problems locating Perspective Efex 6 plugin.
