Update Available - Version 8.0.422
An update is available to Version 8.0.422 (8-Mar-2024)
Compare Transformation: rearranged controls to eliminate duplicate Image B label.
When a transformation is open and you switch between split screen and non-split screen display, the image is now always zoomed to fit unless you hold down the Alt key when switching.
Mask Tool: fixed problem with freehand tool being clipped incorrectly at the top and right edge of the input image.
