Update Available - Version 8.0.421
An update is available to Version 8.0.421 (29-Feb-2024)
Increased the number of situations in which the workspace is autosaved. This means that in the event of a crash you are likely to be able to recover more of your work.
Resize Transformation: now reports old and new size in megapixels and added the option to set the image size in megapixels.
Export command and transformation: added option to set image size in megapixels.
Histogram Tool: if a transformation dialog box is open and just the input image is being displayed, the histogram is computed from the input image. Otherwise, the histogram is computed from the output image. This lets you compare the transformation’s input and output histograms by using the display tool bar, the Ctrl-D keyboard shortcut or by Shift-clicking on the Amount control mask box to toggle between the input and output image.
Text Transformation: added Location and Border Width controls to let you place captions on images that have a border. This can be used to automatically center the text in the top or bottom image border.
