Update Available - Version 8.0.414
An update is available to Version 8.0.414 (20-Jan-2023)
Dehaze transformation: added the ability to add haze as well as remove it and an exposure compensation slider to adjust the brightness of the output image.
Multipoint Gradient transformation: adding a new control point if Match Input Image is unchecked now assigns it the same color as the previous control point. Fixed problems with all the interpolation methods except Shepard and made the method list match the one in Composite Multi-point alignment. This involved removing Hardy and adding Thin Plate, Inverse Multi-quadratic, and Sinc.
Batch operations: fixed problem with scripts generated by File Export transformation. Also fixed a problem with the first image not being restored correctly at the end of a batch process.
Mask Control: added the ability to create rotated rectangle or ovals. Fixed problem with dragging oval gradients by their center point.
Color Lookup transformation: moved load/save/create cube file commands from Settings menu to a tool bar. Added an amount control. Fixed some minor issues.
Color Primaries transformation: fixed a problem with new settings not being applied after loading a saved settings file. A new settings file: Warming.primaries is now included with the install – these settings work well for bringing out fall foliage.
