Update Available - Version 8.0.411
An update is available to Version 8.0.411 (6-Jan-2023)
Magnify transformation: add Square and Diamond shape options.
Lens Distortion: the 5 control points in the overlay that define a line are now numbered and you can quickly scroll to one of them by typing its number.
Composite: re-implemented Multi-point alignment similar to the way it was implemented in PWP 7. Changed the way you specify how control points are dragged since Shift and Ctrl are sed to insert and remove control points in multi-point alignment mode. A full install is required to get 3 new bitmaps.
Updated to ExifTool version 12.72.
Added support for Nik 6 Plug-ins.
