Update Available - Version 8.0.401
An update is available to Version 8.0.401 (18-Nov-2023)
Grid: fixed problem with Omit Edges and minor grid lines.
Mask: fixed problem with loading saved polygons or splines not returning them to their original locations.
Fixed problem causing multiple recalculations when bypassing/un-bypassing multiple transformations at once.
Re: Update Available - Version 8.0.401
Thank you, a saved Spline mask re-opens (loads) exactly where I expected it to be.
One small note: The Spline needs to be saved before pressing the "perform and update" button... perhaps the help documentation could be updated to include this information. It makes sense, in retrospect, but I had to try it both ways to be sure.
If you forget to save it, you can always use the Mask Undo button to get the spline back.
Okay, thank you.
