Clone tool - no source point indication
netaamit
Post by netaamit »
Hi, I'm a longtime user, but I didn't use PWP in quite some time. In the past, Clone worked for me beautifully. But now Clone is changed and I cannot get it to work for me. I shift-click on the target image - no circle. On the source image - ditto. What am I doing wrong? Thank you.
My setup: Win 11 Pro v.21H2 (build 22000.2538), PWP latest (8.0.400).
Re: Clone tool - no source point indication
Not sure what you are doing wrong as it still works the same way as before -- the first time, either click or shift-click should set the source point. In some cases, depending on what else you are doing, you may need to click on the Clone dialog box to return control back to the Clone tool.
netaamit
Post by netaamit »
Uninstall-install (of the same PWP version) did the trick. Reason unknown, and no further interest in exploration. Thank you.
