Saved spline masks don't line up
Hello,
So I've had a chance to play around with saving Spline files. and I notice that when re-loaded the spline selection is smaller and in a new location.
Here is the spline selection when saved:
and here is the spline selection when re-loaded:
I see the same behaviour with saving and loading a Polygon mask...
I am hoping that, for large, complex selections, the mask could be saved mid-progress and then loaded at a later time to complete the selection process.
Thank you for any suggestions.
Re: Saved spline masks don't line up
Should be fixed for the next release in about a couple of weeks. In the meantime, it should work OK as long as the input image is square, so you can temporarily add a border to make the image square and then crop if off when you are done.
