In the documentation under the Settings Menu it appears that one is to have the option Save Curves and Save Color Correction. I don't see either option. For saving, I see only "Save Settings As", and this only saves a *.match reference file in the Match Reference directory.
Earlier the documentation says that Match Reference can correct image color making use of all the color patches on a color reference card. The documentation following the heading Settings Menu says that with the saved information from Match Reference, neutral gray patches can be corrected and further correction of the patches can be achieved using Selective Color Correction. The two statements imply somewhat different capabilities for Match Reference.
What is the file that does get saved in the Match Reference supposed to do?
Match Reference: Capabilities and files
Re: Match Reference: Capabilities and files
It looks like I forgot to implement that feature when I was converting the Match Reference transformation from PWP 7 to PWP 8. I will look into restoring it for the next version.
