closing multiple transformations
Something to consider.
If you select multiple transformations and then click Close selected transformations, you get the confirm message warning for each selected (checked) transformation. When you have a long branch and want to close around 10 transformations, you have to confirm 10 times the same message.
I think one message could be enough for each uninterupted group of selected transformations. In case of a gap in the selected transformations there might be another message if necessary.
Re: closing multiple transformations
Normally, you only have to confirm once. I believe the only time you need to confirm multiple times is if you are closing transformations that are inputs for some other transformation, but maybe I am missing something.
Some of the transformations did have masks attached to them, but not all of them. I will find out.
The problem should not be the mask but if a transformation not being closed depends on a mask from one of the closed transformations or if a transformation not being closed uses one of the closed transformations as an auxiliary input (e.g. a Layout using one of the image in a panel) or a Compare or Composite referring to one of the closed images. If you see the message again, please let me know what it says.
I think I have found it.
It happens when a transformation anywhere below those checked for closing is used as an auxiliary input in Composite. In this case the Composite is in another branch.
It happens even if the this [auxiliary] transformation is bypassed.
Then it goes like this:
First message asks for confirmation to close the "n" transformations
Then follows the warning message for each checked transformation:
Closing the selected transformation will change one or more inputs or masks in the transformations.
After the message for the last checked transformation is OK-ed, the checked transformations are closed in one step.
OK thanks, will check it out.
