Update Available - Slide Show Viewer 1.0.11
An update is available to Version 1.0.11 (6-Mar-2023)
Fixed problem with right click on a thumbnail to select Delete Current Slide not working.
Added a new Curtain transition type.
Fixed some problems with slide transitions in Manual mode.
Separated the Slide Show Viewer bitmap files from the ones used by Picture Window, so uninstalling Slide Show Viewer will not delete some of the Picture Window bitmaps.
Re: Update Available - Slide Show Viewer 1.0.11
A message when starting SSV:
Screenshot 2023-03-07 135036.png (39.04 KiB) Viewed 1046 times
