Update Available - Version 8.0.345
An update is available to Version 8.0.345 (14-Jan-2023)
The Mask Freehand Outline tool now clips automatically when you try to draw outside the edges of the input image.
When a size-preserving transformation starts up, if the entire input image is visible, the display is now zoomed to fit if the initial display is split screen. As before, if the input image is zoomed in, both halves of the split screen are also be zoomed in to the same level as the input image.
