Update Available - Version 8.0.340
An update is available to Version 8.0.340 (23-Dec-2022)
Added a help topic on Installing Picture Window, covering portable installation and installing for multiple users.
When saving scripts with Image Copies (rather than Image Names), the pathnames of the associated image files stored in the script file are no longer relative to the folder containing the script file but are now absolute. This fixes several problems, including missing file errors when loading autosaved workspace scripts. If the folder containing the script file and images folder is renamed or moved, you will get a missing file warning when loading the script but if you continue, Picture Window will offer to substitute image file pathnames in the new folder. Old script files will continue to work the same way as before, while new script files will use absolute pathnames.
Re: Update Available - Version 8.0.340
Post by Robert Schleif »
Thank you for addressing this issue.
