Update Available - Version 8.0.333
An update is available to Version 8.0.332 (24-Nov-2022)
In the menu displayed when you click on the Amount box, the list of images and masks that can be used to initialize the Amount Mask is now sorted with the most recent transformations first and with masks associated with a transformation following the transformation in ascending order.
The Enable Proofing and Enable Gamut Alarm buttons are now displayed with a yellow background when they are depressed to make it more obvious they are active. A full install is required to get the new bitmaps.
In the Color Picker, if a color wheel is being displayed, holding down the Shift key will lock the hue and holding down the Ctrl key will lock the saturation when you are dragging the control point.
