Update Available - Version 8.0.309
An update is available to Version 8.0.309 (6-Aug-2022)
Export command and transformation now support a new resizing method which makes the output image fit within a bounding box of given pixel dimensions and fills in any blank space with a solid border color you can select.
Right-clicking on the Favorites button in the main tool bar, instead of displaying the Favorites dialog box, immediately selects the last transformation you selected from the Favorites list, if any. Left click works as before.
Curves and Histograms.pdf: added new examples at the end of the document illustrating several useful contrast enhancement techniques. Recommended reading.
