Update Available - Version 8.0.302
An update is available to Version 8.0.302 (10-Jul-2022)
Color Balance – added vertical separator between controls and color curves. If you widen the dialog box, you can now drag the separator to widen the Amount control.
Multi Color Balance – If you widen the dialog box, you can now drag the vertical separator to widen the Amount control.
Slide Show Viewer – now works if some or all of the image files are shortcuts. You can use this to create a slide show of selected files from various folders without having to make redundant copies of them.
Added support for Nik plugins version 5.
Restored Apply buttons in all transformations in order to make Preview windows work smoothly.
Preview windows now replace clipped highlight and shadow pixels with colors as defined in File Preferences.
Readout Tool: fixed Lab readouts for images with gray profiles.
Re: Update Available - Version 8.0.302
It seems to do that but without taking into account the Colour Management, as Winfried noticed in another post.
