Update Available - Version 8.0.285
A minor update is available to Version 8.0.285 (24-Apr-2022)
File/Save Back: fixed problem of sometimes proposing to save in the wrong folder after loading a script.
File/Resave: fixed problem of sometimes proposing to save in the wrong folder after loading more than one script. Unfortunately, fixing this required adding new information to script files, so it will not work with pre-existing scripts or workspace scripts.
Added warning to File/Save commands if the current image is not at the end of its branch.
Transformations.pdf: added an example of using the Channel Mixer in the Monochrome transformation.
Re: Update Available - Version 8.0.285
Post by Robert Schleif »
Is it possible that the new information that is needed for Re-Save to work could be added to pre-existing scripts by a utility program that would find and update older scripts?
Thanks for making this suggestion. Having finally gotten everything to work, I was able to go back change the code that loads scripts to infer the missing information from old script and workspace script files, so no utility is necessary. Will upload a new release shortly.
