Save Back
Save Back
Post by Robert Schleif »
If I open two branches via their scripts, modify the first branch and then select Save Back while the last image of the first branch is selected, the dialog box that opens presents me with the location of the script for the second branch. This behavior is not so convenient for me nor is it the behavior that I expect from the documentation on Save As/Save Back .
By the way, is Re-Save now safe to use in all situations?
Re: Save Back
As far as I know, Re-Save is safe now, but I still visually confirm the name it is saving under just to make sure.
Currently, it works based on the last script file you loaded but I can see how this can create a problem is you load more than one. I will think about possible solutions. In the meantime, you need to be careful with this situation.
