Problem with saved Frame-Transformation or scripts
If I choose an image in the Frame tab of the Frame transformation it works fine.
But when I reload a saved Frame (either with the setting menue, or ctrl-R, or as part of a script) the image of the frame is not loaded.
I had a look with an editor at the the *.frame files. I didn't find any link to an image. So I suppose the link from the Frame tab is not saved.
Re: Problem with saved Frame-Transformation or scripts
When you save transformation settings, links to other images are not saved. This would not work anyway unless you also saved all the other transformations that produced the linked images and the one that produced them, etc. To save links to other images, you need to save a script or workspace script file.
