Re-Save Issues
Re-Save Issues
I discovered that the current implementation of the File/Re-Save command has some serious problems. It works OK if you open a script that produces an image file, make some modifications and then re-save the same image file. However, there are two problems I have encountered. First the command is not grayed out correctly. Second, it can overwrite the wrong file if you start editing another image file after loading a script.
I think I have a fix for this that I am still testing out, but In the meantime, please be careful using this command.
