Update Available - Slide Show Viewer Version 1.0.8
An update is available to Version 1.0.8 (21-Mar-2022)
Slide Show Properties Dialog Box: added Save as Default button which saves the current slide show properties as the defaults for future slide shows.
You can now create and run a new slide show with default settings by simply dropping an image folder icon onto the Slide Show Viewer icon using Windows Explorer.
Added new File/Create Slide Show from Folder command to build a slide show from a folder using the default settings and default slide show name (index.ssi). This is like dropping the folder onto the Slide Show Viewer icon.
Double-clicking on a slide in the Slide Show window now toggles between Fit and Crop. You can still use the keyboard shortcuts F and C.
Fixed problem causing a slide show not to run once it was stopped by pressing Esc.
Fixed installation settings to place executable in the correct folder as a 64-bit application.
