Update Available - Version 8.0.269
An update is available to Version 8.0.269 (19-Jan-2022)
Hue Saturation transformation: Hue Change readout is now in degrees instead of percent. Fixed bug causing crash when using probe in HSL mode. Added tool bars to set the selection color to red, green, blue or white and to set the selection display to histogram only/histogram plus selection/selection only. Filled out the description in the help file and added a description of the transformation to Transformations.pdf. There are several new bitmaps so a full install is required.
Mobius Transformation: fixed problem causing shift-clicking on Amount mask box not resetting the output image.
Re: Update Available - Version 8.0.269
Mobius: thank you. But now changes to the Amount slider have no effect; changes stay at 100%. Shift-click on mask works as it should.
