Conditional curve when Y axis is hue : axis not showing color scale
The X axis shows hue scale in color :
2021-12-05 CondCurve X-hue Y-brightness.png (39.22 KiB) Viewed 2435 times
The Y axis does not :
2021-12-05 CondCurve Y-hue X-brightness.png (40.85 KiB) Viewed 2435 times
Re: Conditional curve when Y axis is hue : axis not showing color scale
The vertical axis is hue change, not hue.
Re: Conditional curve oddity
Thank you - perhaps some clarification in the help and manuals could clarify the intended behavior.
I also found this odd X brightness - Y brightness control panel display showing the hue scale on the X axis :
2021-12-05 CondCurve Y-brightness X-brightness.png (40.76 KiB) Viewed 2426 times
Any idea what you did to get that display?
Unfortunately no detailed steps. I was trying with different selections in the drop-down lists to understand how the transform works
