An update is available to Version 8.0.253 (27-Nov-2021)
Macros in text: fixed problem with Date and Time Taken showing as yyyy:mm:dd instead of yyyy-mm-dd.
Speeded up some internal conversion routines.
Masks: fixed problems with polygon and spline masks for large images.
Brightness Curve: fixed problems with the way black and white curves were handled if the black and white sliders were not set to 0% .. 100%. The black and white sliders now work differently and both default to 100% (see the help file and Transformations.pdf for details and examples). Now, the black slider modulates the effects of the black curve and the white slider modulates the effect of the white curve. For compatibility, the black and white sliders in pre-existing scripts are automatically updated to 100% .. 100%. This should produce the same results as 0% .. 100% previously. The previous results for settings other than 0% .. 100% were invalid.
Right-click on the bypass icon of a thumbnail in the image browser now closes any open transformation dialog box before forcing a recalculation of the downstream images. This prevents a crash in transformations that have an Amount control, in some specific cases.
Update Available - Version 8.0.253
Re: Update Available - Version 8.0.253
Thank you, it works great !
