Update Available - Version 8.0.252
An update is available to Version 8.0.252 (22-Nov-2021)
Color Picker: added support for tab keys, now sets focus to the first text control on startup, and fixed problem with text entry delay always 1 sec instead of following the File/Preferences setting.
Text transformation: fixed problems with applying colored text to black and white images and possible crash when closing dialog box.
Level transformation: typing 1 or 2 while the input image is displayed scrolls the input image if necessary and moves the cursor to the left or right end of the reference line. This provides a quick way to fine tune the endpoints while the image is zoomed in. Also fixed a problem that could cause unexpected results when switching to an input image of a different size.
Fan transformation: fixed problem causing output to be reversed left to right for the Full Circle method.
