Update Available - Version 8.0.251
An update is available to Version 8.0.251 (21-Nov-2021)
Added a Preview feature to let you display the results of one transformation while editing another. See the new help file under Preview Window for details and an example.
Multipass Sharpen: simplified the interface for selecting multiple passes. You no longer need to go to the Settings Menu to select the number of passes – it is now fixed at 3. Just use the pass enable/disable buttons to turn off the passes you don’t want. In addition, clicking on one of these buttons now selects the tab for the corresponding pass. Tabs for disabled passes are grayed out but can still be selected.
