Update Available - Version 8.0.248
An update is available to Version 8.0.248 (9-Nov-2021)
Fixed problem causing crashes related to mask images inherited from other transformations, accidentally introduced in previous release.
Color Line control: cursor now changes shape when you hover over a tic mark or number. You can now Right Click on a color line to get a menu to add or remove a control point. You only get the remove option if you right click near an existing control point other than the first or last which cannot be removed.
