Update Available - Version 8.0.193
An update is available to Version 8.0.193 (24-Jan-2021)
After geotagging, a status dialog box is now displayed that captures any warnings, error messages or summary information resulting from the geotagging process.
Raw Develop: fixed problem of curve histogram not being displayed initially if no corrections are being made.
Add profile for Sony 55mm f/1.8 ZA lens.
Fixed problems with cursor incorrectly reverting to crosshair after clicking OK on a number of different transformations.
File Save: Added a refinement to the way original pathnames are determined. The original pathname of a top-level transformation other than a File Open or Copy was previously undefined. Now, if the top-level transformation has exactly one input, the filename associated with that input becomes the original pathname. So, for example, if a Layout or Stack Images incorporates one or more copies of the same image and no other images, its original pathname is the original pathname of its single input image, and a version of this original pathname is used to generate the default filename. If a transformation has no inputs or more than one input image, the original image is undefined as there is either no metadata to save or it is ambiguous which metadata to save.
