Update Available - Version 8.0.192
An update is available to Version 8.0.192 (21Jan-2021)
Mask Flood Fill Tool and Fill Transformation: rewrote to avoid potential stack overflow problems for large, complex fill regions.
Mask: fixed memory leak when re-opening a mask dialog box.
Image Info: fixed problem with Taken date display – month number was off by one.
Card to Folder and Geotag Folder: fixed various geotagging problems for some cases and added new options to set time zone offset from GMT and save originals. See help file for details. If you are geotagging, also check out the updated Geotagging Images.pdf.
Updated to Exiftool 12.15
