Update Available - Version 8.0.190
An update is available to Version 8.0.190 (7-Jan-2021)
Line/Arrow tool: applying text or border color to a B&W image now uses the luminance of the color to select a gray level – previously it used the red channel. This makes it consistent with what happens with the line/arrow color. Fixed problem causing existing control points and text box overlay not to be displayed on startup in some cases. Also fixed several problems with applying text boxes to 16-bit B&W or 48-bit color images.
Text Transformation and Lines, Arrows Text Tool: added a new text justification tool bar distinct from the Alignment control. Now you can independently set the justification of multiline text (left/right/center) vs the alignment between the text box and the control point. This change requires a full install to get 3 new bitmaps.
Updated to Exiftool 12.14
