Update Available - Version 8.0.189
An update is available to Version 8.0.189 (4-Jan-2021)
Fill tool: added Remove All Control Points to Settings menu.
Favorites: fixed problem with Rotate-Mirror in the default favorites you get if you have never run Picture Window. If you already have a favorites file, you can fix it by removing Rotate-Mirror and adding it again. The correct name is Rotate/Mirror which should show up instead.
Updated to Exiftool 12.13
Raw Develop: fixed problems with incorrect curve and/or histogram displayed in some cases.
