RAW and selecting which tabs contribute to preview
A suggestion for RAW: since it uses tabs, similarly to Adjust, I was thinking that it may be useful to have something similar to what Adjust do - have buttons to turn on and off individual tabs.
- 2020-11-30_173654.jpg (2.03 KiB) Viewed 1422 times
Re: RAW and selecting which tabs contribute to preview
I originally had a tool bar such as the one you are suggesting. I removed it because it is easy to forget that one or more of the buttons is raised and accidentally bypass changes you intended to make.
Adjust has the same issue -- originally I ignored the tool bar when doing the final recalc on OK, but this has the problem that you what you see is not what you get.
