Update Available - Version 8.0.176
An update is available to Version 8.0.176 (27-Nov-2020)
Fixed problem in Google Maps lookup in Image Info for locales that use a character other than a period as a decimal point.
Create Lens Profile command: fixed problem with some cameras not storing Lens Model in their raw file EXIF data. If Lens Model is missing, ExifTool is now called to determine the Lens ID from the Maker Note metadata instead. Also added progress indicator so the command can be canceled.
Create Profile: restored accidentally omitted Expand Target Dynamic Range option to Settings Menu.
Rebuilt all camera profiles using the Expand option.
Illegal filename characters in camera make or model or lens model are now replaced with underscores when generating default names for camera and lens profiles.
