Update Available - Version 8.0.172
An update is available to Version 8.0.172 (18-Nov-2020)
The File/Create Lens Profile command and Raw Develop transformation are now available to try out. They are both still works in progress as I am still tinkering with them. I have included a few camera and lens profiles – I will try to add some more in future releases, especially for Sony full frame and Micro 4/3 which is mostly what I have here.
Breakpoints on bypassed transformations are now ignored.
Mask Feather progress bar now has a Cancel button.
Create Profile: Added an alternate set of reference files for SpyderCheckr 24 and 48 as the standard reference file did not accurately match my copy of the target.
Raw files: when opening raw files, the camera white balance setting at the time the photograph was taken is now applied to the image. This improves color rendition considerably, but it changes the way pre-existing scripts process raw files.
Warp: fixed off-by-one error in image size when editing an existing transformation.
Lens Profile Target: fixed problem causing target width not to be restored correctly when editing the transformation.
