Mask Paint Tool Doesn't Work Unless Tool is Moved
jfoster
Post by jfoster »
To reproduce:
1. Open PWP 8 (Rev. 164)
2. Create the Test Pattern Checkerboard image.
3. Open the Mask Transformation.
4. Select New Mask
5. Select the Mask Paint Tool
6. Click the Mask Paint Tool on the image without moving the Mask Tool.
7. Note that no mask appears.
rfuerman
Re: Mask Paint Tool Doesn't Work Unless Tool is Moved
Post by rfuerman »
Just made a mask on a jpg image with the brush & works fine here. Try bumping up the tool radius, the default is very small. Bob
Thanks, I can reproduce the problem here -- will fix for next release.
