Update Available - Version 8.0.139
An update is available to Version 8.0.139 (29-Aug-2020)
Clone, Paint and Smudge Tools: Changed the way Undo works to reduce memory usage and modified the way the screen updates as you paint strokes. Fixed a problem with Undo not removing the first stroke in some cases.
Distort: current control point is now displayed as a filled circle.
Color Picker: fixed problem of the pastel mode color wheel being displayed incorrectly for saturated colors. It now switches automatically to full mode if the color is more than 50% saturated.
Color Line Control: added Make All Colors Gray to Settings menu. This converts all colors to a neutral gray of the same luminance. Also added By Luminance to Settings menu. This sorts the colors by their luminance and positions them to make the luminance of the color line vary linearly from one end to the other.
Tint Transformation: Added Brightness Channel and Blending Mode controls. See the update help file or Transformations.pdf for details.
Batch processing – the Batch progress dialog box is now left visible when reaching a breakpoint so you can tell which file is being processed.
Level Transformation: the control points are now constrained to stay within the input image.
