Update Available - Version 8.0.138
An update is available to Version 8.0.138 (26-Aug-2020)
Distort Transformation: For Shepard method, added the ability to assign weights to individual control points.
Paint Tool: Added Color Burn and Color Dodge painting modes.
Levels and Color Tool: Changed the way Undo works to reduce memory usage, and modified the way the screen updates as you paint strokes. Fixed a problem with Undo not removing the first stroke. Also fixed some spacing issues in the dialog box.
Re: Update Available - Version 8.0.138
This fix for the Levels and Color Tool works well - tried the same sort of sequence of operations, and memory usage did not increase past 357MB. Painting seems smoother for sure.
Interesting addition for Distort.
Thank you (once again) for your enthusiastic support!
