This question is definitely not urgent. It's about Compositing/blending images. Below is a blend of two images which I achieved with PWP Composite and a manually-adjusted gradient mask. It worked fine as far as it went.
But there are other modes of blending, one from Sean McHugh's Cambridge in Colour (https://www.cambridgeincolour.com/tutor ... ftware.htm). Would it be possible and/or desirable to introduce something like this (e.g. maybe via some high pass/low pass variation)?
Multi-resolution spline blending
- When the music changes, so does the dance.jpg (72.88 KiB) Viewed 1527 times
- enblend-enblended.jpg (18.24 KiB) Viewed 1527 times
Re: Multi-resolution spline blending
Apparently that latter apple/orange blend was done in an open-source Emblend code: https://en.wikipedia.org/wiki/Enblend
Here is the original paper describing the technique:
http://cs.nyu.edu/~fergus/teaching/comp ... line83.pdf
