v8.0.117 Multiple Line and Arrow error
Ref: v8.0.117
1) Open a 48-bit image and OK several Line and Arrow transformation labels... ...then save Script with image names.
Screenshot (15)-1.jpg (81.87 KiB) Viewed 2210 times
2) close images in browser/workspace.
3) Open the resulting 1) Script... ...error occurs.
Screenshot (16)-1.jpg (67.26 KiB) Viewed 2210 times
--------------------------- *.script ------------------------------------------------------
script 1.0
PWP_Version ″Picture Window Pro 8.0.117″ saved ″26-June-2020 10:02:56″
color_management enabled 1 on_mismatch 0 on_batch_mismatch 1 acs_profile ″sRGB Color Space Profile.icm″ gray_acs_profile ″Gamma 2.2.icm″ wcs_profile ″sRGB Color Space Profile.icm″ gray_wcs_profile ″Gamma 2.2.icm″ monitor_curves_file ″″ monitor_curves_enabled 0
image index 1 caption ″File Open - aDSCF2946-2-HDR(5)2631_Default Orton 16x9r v1.tif″ saved_as ″″ saved_on ″″ parent -1 bypass -1 same_size 0 size_specific 0 breakpoint 0 n_inputs 0 n_masks 0 command ‴file_open 0 n_files 1 current 0 from_default 0 multiple 0 file1 ″C:\Users\birch\Pictures\2020 Photos\200625 BBay Sunset\2946\aDSCF2946-2-HDR(5)2631_Default Orton 16x9r v1.tif″ time1 ″20200626 155846″‴
end_image
image index 2 caption ″Line and Arrow Tool″ saved_as ″″ saved_on ″″ parent 1 bypass 0 same_size 1 size_specific 1 breakpoint 0 n_inputs 0 n_masks 1 command ‴arrow 0 nx 4028 ny 2266 amount 0.5 -1 0 0 ″Amount: ″ ″Mask″ line_width 5 head_size 5 transparency 0 color ffffff heads 0 style 0 line_style 0 has_text 1 text_info 0 ″Birch Pt″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.7689 0.4233 display 2 sync_scroll 1 auto_preview 1 narrows 1 arrow0 5 5 0 ffffff 0 0 0 1 0.7687 0.4232 0 0 1 1 has_text0 1 text_info0 0 ″Birch Pt″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.7689 0.4233‴
end_image
image index 3 caption ″Line and Arrow Tool″ saved_as ″″ saved_on ″″ parent 2 bypass 0 same_size 1 size_specific 1 breakpoint 0 n_inputs 0 n_masks 1 command ‴arrow 0 nx 4028 ny 2266 amount 0.5 -1 0 0 ″Amount: ″ ″Mask″ line_width 5 head_size 5 transparency 0 color ffffff heads 0 style 0 line_style 0 has_text 1 text_info 0 ″Pt Roberts″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.0612 0.4112 display 2 sync_scroll 1 auto_preview 1 narrows 1 arrow0 5 5 0 ffffff 0 0 0 1 0.0612 0.4111 0 0 1 1 has_text0 1 text_info0 0 ″Pt Roberts″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.0612 0.4112‴
end_image
image index 4 caption ″Line and Arrow Tool″ saved_as ″″ saved_on ″″ parent 3 bypass 0 same_size 1 size_specific 1 breakpoint 0 n_inputs 0 n_masks 1 command ‴arrow 0 nx 4028 ny 2266 amount 0.5 -1 0 0 ″Amount: ″ ″Mask″ line_width 5 head_size 5 transparency 0 color ffffff heads 0 style 0 line_style 0 has_text 1 text_info 0 ″Vancouver, BC Canada″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.5873 0.4111 display 2 sync_scroll 1 auto_preview 1 narrows 1 arrow0 5 5 0 ffffff 0 0 0 1 0.5872 0.4109 0 0 1 1 has_text0 1 text_info0 0 ″Vancouver, BC Canada″ ″Arial″ 80 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.5873 0.4111‴
end_image
image index 5 caption ″Line and Arrow Tool″ saved_as ″″ saved_on ″″ parent 4 bypass 0 same_size 1 size_specific 1 breakpoint 0 n_inputs 0 n_masks 1 command ‴arrow 0 nx 4028 ny 2266 amount 0.5002 -1 0 0 ″Amount: ″ ″Mask″ line_width 5 head_size 5 transparency 0 color ffffff heads 0 style 0 line_style 0 has_text 1 text_info 0 ″Birch Bay, WA USA″ ″Arial″ 100 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.2313 0.0644 display 2 sync_scroll 1 auto_preview 1 narrows 1 arrow0 5 5 0 ffffff 0 0 0 1 0.2313 0.0644 0 0 1 1 has_text0 1 text_info0 0 ″Birch Bay, WA USA″ ″Arial″ 100 4 1 0 0 ffffff 0 255 255 8 0 0 0 0 0 0 -45 50 0 0.2313 0.0644‴
end_image
end
P.S. Yesterday evening's sunset as viewed from our waterside yard.
Re: v8.0.117 Multiple Line and Arrow error
I just fixed this and will upload a new version shortly.
