Update Available - Version 8.0.116
An update is available to Version 8.0.116 (24-Jun-2020)
Text transformation and Text Control: text strings are no longer automatically updated after the keyboard delay set in File/Preferences. There is now a check mark button just above the text entry field that you have to click to get the text to update. This means you no longer have to enter strings quickly and without pausing, but there is an extra step to get changes to be processed.
Lines/Arrows/Text Tool: fixed problem with semi-transparent line and curve artifacts where the line or curve segments join.
Change Profile: added error message if color management is disabled or target profile is an input (scnr) profile.
Size To Fit Transformation: Added Scale To Fit – No Border option. This resizes the cropped area of the input image, preserving its proportions, so the output image fits inside the reference rectangle. This is similar to Scale To Fit except the output image is not padded out to the full reference rectangle with the border color.
File/Export and Export transformation: Added bounding box option to resize the image to fit a rectangle of given width and height.
