Update Available - Version 8.0.101
An update is available to Version 8.0.101 (17-May-2020)
Crop: fixed problems adjusting cropping rectangle when input image changes dimensions.
Warp: improved accuracy at which settings are saved.
Added tests for missing folders to new code to make folders accessible from the File Open and Save dialog boxes.
Added tests for missing default folder where it is referenced. If the default folder cannot be accessed, the Windows My Pictures folder is used instead. If that cannot be found, C:\ is used. A warning is issued if the default folder is missing or inaccessible.
