Workaround for slow Bilateral Sharpen transformation
Charles2
Post by Charles2 »
Bilateral Sharpen at a large radius takes around 20 seconds to compute on my system. All the other frequently used transformations are speedy.
When modifying transforms in a sequence that has a Bilateral Sharpen at or near the end, the delay becomes tedious. My workaround is to do the Bilateral Sharpen, close it, and recall it (Ctrl-R) when I am "done" with an image. Is there a better workaround?
Re: Workaround for slow Bilateral Sharpen transformation
You can just click the bypass button on the Bilateral Sharpen transformation until you are ready to run it.
If you use one of the newer NVIDIA cards it runs a lot faster using CUDA.
Charles2
Post by Charles2 »
Thank you. I knew there was a Bypass transformation, but I did not know about the bypass button. RTFM yet again.
Another idea:
viewtopic.php?f=5&t=2392
For sharpening, cropping may work better than dowsampling as it will give 1:1 preview, and could be turn off with bypass button quickly as well.
